Multifunction DAQ
Using Measurement Studio ActiveX in Labview
Are there any examples of using measurement studios ActiveX controls in Labview? Specifically would like to be able to use CWUIControlsLib.CWGraph as I need to have the ability to use the annotations capability it has. Labview's graph/charts don't seem to have this option. I'm not well versed in using activeX controls in labview so I not sure how to go about sending data to a measurement studio graph if it is inbedded into my Labview VI. Help would be greatly appreciated.
(2,594 Views)
Hey Brian,
There are two places where you could go to look for examples. The first place you could go is to the Code Library here in the NI Developer Zone. I just did a quick search for examples with Measurement Studio, and some 230+ examples came back.
The second, and probably more efficient, place to look is for the examples that get installed when you install NI-DAQ on a computer which already has Measurement Studio installed on it. These would be located under Program Files\National Instruments\NI-DAQ\Examples\Visual Basic with Measurement Studio\ or at Program Files\National Instruments\MeasurementStudio\VB\Samples\DAQ.
It seems that you question is more related to actually using Measurement Studio and LabVIEW together. If this is the case, you may wa
nt to re-post your original question but in the Measurement Studio discussion forum. I hope that this information helps you out.
Jared A
(2,594 Views)
