Multifunction DAQ
Using CB-68LP, for simple voltage vs. time measurement
I created a simple circuit with 3 resistors in series.   when you connect the resistors to the terminal block, do you need to make two connections? one to say analog channel 1 and analog ground for each resistor?  i tried that and it seems to give wrong data, i tried just making one connection per resistor, analog channels 1-3 and it seems to give closer results to my multimeter.  am i doing something wrong?
(2,939 Views)
Er, if you connect the resistors in series *and* you connect each resistor to ground, aren't you grounding everything?
It's kind of hard to tell exactly what you're doing. A diagram or more detailed description would help.
It sounds like you may not really have a good grip on what you're trying to do. Maybe you should tell us what you're trying to measure, and we can offer alternative strategies.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(2,931 Views)
