Multifunction DAQ
Using Analog Input and Output at Once
I'm trying to get analog input and output working at the same time, namely in MS Visual Studio with C++.  Currently, I've run the Acq-IntClk analog input example, which works, but the voltages are off.  However, the expected voltage drops are still present.  When measuring zero voltage, the output has a tendency to drop ~.1V every two or three elements in the array.  For example, when exposed to no voltage, data[0] will start at -5.9V, and then decrease to -6.0V at around data[2].
Now on to the actual issue:
#include <stdio.h>
#include <math.h>
#include "NIDAQmx.h"
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
	int         error=0;
	TaskHandle  taskHandle=0;
	TaskHandle	taskHandle2=0;
	TaskHandle	taskHandle3=0;
	int32 read;
	float64     data[4000];
	float64		data2[100];
	char        errBuff[2048]={'\0'};
	int			i=0;
	int32   	written;
	for(;i<4000;i++)
		data[i] = 10.0*(double)i/4000.0;
	// DAQmx Configure Code
	DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
	DAQmxErrChk (DAQmxCreateTask("",&taskHandle2));
	DAQmxErrChk (DAQmxCreateTask("",&taskHandle3));
	DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0","",-10.0,10.0,DAQmx_Val_Volts,NULL));
	DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",500,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,4000));
	DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle2,"",10.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,100));
	DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle2,"Dev1/ai0","",DAQmx_Val_Cfg_Default,0,8,DAQmx_Val_Volts,NULL));
	// DAQmx Write Code
	DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,4000,0,10.0,DAQmx_Val_GroupByChannel,data,&written,NULL));
	// DAQmx Start Code
	DAQmxErrChk (DAQmxStartTask(taskHandle));
	DAQmxErrChk (DAQmxStartTask(taskHandle2));
	DAQmxErrChk (DAQmxReadAnalogF64(taskHandle2,100,10.0,DAQmx_Val_GroupByChannel,data2,100,&read,NULL));
	// DAQmx Wait Code
	DAQmxErrChk (DAQmxWaitUntilTaskDone(taskHandle,10.0));
Error:
	if( DAQmxFailed(error) )
		DAQmxGetExtendedErrorInfo(errBuff,2048);
	if( taskHandle!=0 ) {
		// DAQmx Stop Code
		DAQmxStopTask(taskHandle);
		DAQmxClearTask(taskHandle);
		printf("DAQmx Error: %s\n",errBuff);
	printf("End of program, press Enter key to quit\n");
	getchar();
	return 0;
This code just integrates my two working parts, the analog in and output, but when I run it, I get Error -200477.
Thanks in advance.
Message 1 of 1
(3,460 Views)
