Multifunction DAQ
Use M-Series DAQ with software supporting only NI-DAQ 6.9.1
I am using a software in my test system that only supports devices compatible with NI-DAQ 6.9.1. My preferred DAQ-device is an M-series card mit NI-DAQmx. Is there any possibility to use this card with my software? I only want to read and set digital lines and to read analog ins.
Thanks for help.
(3,238 Views)
hello fkantz,
as you can see here, the M-Series only work with NI-DAQmx: http://www.ni.com/support/daq/versions_pci_pxi.htm
There are Copatibility VI's, which allow you to use Trad.DAQ VIs with new DAQmx devices (http://digital.ni.com/softlib.nsf/websearch/9D67F671BCC6850586256E630059308B) but you can't use a DAQmx device (like the M-Series) with older driver.
greets
(3,226 Views)
Hello Waterman,
since I am not using LabView I cannot use compatibility VIs. Is there also a toolset of compatibility functions in c++ for this?
fkantz
(3,221 Views)
sorry, i don't think so...
but perhaps this link will help you
(3,217 Views)
