Multifunction DAQ
Unable to connect LabVIEW program to NI 9146 module
I'm having trouble connecting my LabVIEW program to an NI 9146 module to retrieve data from a pressure sensor. I created a subVI to process the FPGA data, and the compilation completes successfully. However, I still can't access the sensor data.
As soon as I run the main VI, the program crashes and an error message appears immediately. I've attached the error message, the project tree of my LabVIEW setup, and the section of code in the main VI that isn't working.
Thank you in advance for your help!
Yoni
(99 Views)
Try the steps in Error -63040 Connection Not Established Using LabVIEW FPGA
https://tmesystems.net/
(69 Views)
