Multifunction DAQ
USB6363 Digital output
Hello, I use USB-6363 board to generate some IO signals.
1. When I try to run an example "Digital - continues outout.vi" I get digital pulses with 12.5% duty cycle at the output pin. Is it a way to make it continues stable logic level high or low?
2. When I try to select an FPIx (port 1 or 2) pin as an output, I get the following error message: "Err. 201062: Selected lines do not support buffered operations.
Ensure only lines that support buffered operations are being used in the task. If using change detection timing, the task must be changed to non-buffered to support these lines."
Is it a way to get around this?
Message 1 of 1
(602 Views)
