Multifunction DAQ
USB TC01 timing
Hi
Could somebody tell me how timing is handled with the USB TC01 device ? I tried using a standard program like the one presented in this tutorial : http://www.ni.com/swf/devzone/ai/ but I get an error message saying that sample clock is not a valid argument.
Thanks !
(3,311 Views)
This device has a fixed sample rate of 4S/sec you can't change it so trying to set it causes and error.  essentially you don't need to worry about timing on a temp measurement task on this device other than to realize that if you request 100 readings you'll get a Timeout error if the timeout value is not greater than 25 seconds
"Should be" isn't "Is" -Jay
(3,299 Views)
