Multifunction DAQ
USB Single Module Carrier
Good Morning,
Could 2 NI USB-9162 single modules be connected to and used on the same PC?  Would the MAX configuration possibly change anytime the PC power is cycled (device # reversed)?
ed
(2,773 Views)
Hi edlad,
There should be no problem connecting two NI USB-9162 to the same PC. Also there is no need to worry about the device numbers changing in MAX since the first time you connect your device, MAX will assign a new device number to it and associate its serial number. So even if you had two identical modules, they would have different serial numbers which will be assigned to different device numbers in MAX.
I hope this helps,
S_Hong
S_Hong
(2,748 Views)
