Multifunction DAQ
USB-6215 in Windows Vista? Nidevmon service fails to start...
I have been trying to install a USB-6215 in Windows Vista Ultimate without success.
As a summary:
I have installed first LabVIEW 8.2.1 and NI-DAQmx 8.5. No other previous NI software is installed in the computer. After rebooting I plugged the USB board but the "USB-621x loader" failed to initialize. I tried to start the service nidevmon manually, but it fails to start.
I have also tried to "repair" all the NI software installed in the computer.
There is no antivirus software installed in the equipment. The firewall is turned off. I have tried also turning off the Windows Defender that comes with Windows Vista. When I log into the computer, I have administrator privileges.
I think that this service "NI device Monitor" is the one needed to install the National Instruments boards into the computer, isn't it? Does it mean that I will not be able to install any other card in the computer with Windows Vista? From the web page of NI, the USB-6215 was listed as a compatible device with Windows Vista, with the NI-DAQmx 8.5, so I don't know what else to try...
Any suggestions will be very welcome!
(3,596 Views)
I have a customer that is also interested in this same issue:
"installed the runtime engine but with no joy. When I insert the
disc for the NI software and drivers that comes with the DaQpad USB-6215 the
message I get is that NI does not support Windows 64 and the installation
process just stops."
As the original post is > 2 years, is there a related link that recommends a solution?
(3,087 Views)
Hope this will solve your problem.
(3,082 Views)
