02-23-2013 12:55 PM
Hi all,
I am using the Analog Output to play many sequential files through that are ~30 seconds long. As I send them to to the DAQ, I also plot them at the same frequency on screen just for a visual reference (Obviously they aren't perfectly aligned, but that is fine for what I'm doing).
Here is a basic flow chart; note the 2 paralell tasks of plotting and sending to AO1:
[Open File 1] --> [Send through AO1] --> [Loop to the Next] --> [Open File 2] ---> [Send through AO2], etc. etc.
[Display on a Chart] [Display on a Chart]
I initially wrote this (very simple!) code for the NI9263 and it worked great. Recently I acquired a NI 6212 (USB Module) and find that it doesn't work right!
It still opens and closes files just fine; the chart continues to update and show to me that I am indeed loading the next file in the set. However, the DAQ stop outputting after just the first file. I don't know why it is doing that.
I've tried the following permutations:
Windows 7 PC
Windows XP PC
NI9263 (I tried two different ones, both are fine!)
USB-6212
Labview 2011
Labview RunTime 2011
Even on an old Win XP PC, I can get the NI9263 to work just fine...
Some notes:
I'm outputting on AO1 using both the 9263 and the 6212.
I have a DAQmx task configured for N Samples, and set it to write the same number of samples in the file (2000 points per file, thus I have it set to n=2000), and set it to the correct frequency (100Hz)
Any help on why the 6212 stops outputting on the file file, but the 9263 just keeps going on?
02-26-2013 10:39 AM
I just wanted to briefly ask if you are receiving any errors in either case.
Also, which chassis are you using the NI 9263 in?
Eric
02-26-2013 11:40 AM
cDAQ 9172.
No errors are thrown in either case
