Multifunction DAQ
USB-6210 DAQ Problem with Labview 2011 Windows 7
Using a Windows 7 64 bit operating system, the USB-6210 DAQ board performed well under Labview 2010. When loading Labview 2011 onto the computer, including the provided DAQ drivers, the computer now does not recognize USB-6210. What do I need to do to get the right driver back in place?
(3,519 Views)
Hello crsahi,
Here are a few things we need to double check:
- did you make sure to install the drivers after LabVIEW 2011? If not, try repairing the install
- was the device loader enabled?
Take a look at the following KnowledgeBase article and let me know if that doesn't solve your problem:
Jacob R. | Applications Engineer | National Instruments
(3,500 Views)
Jacob,
Thanks for your suggestions. I had to change the settings on the device loader and re-install the drivers. Seems to work.
Thanks for your help,
Carl
(3,481 Views)
