Multifunction DAQ
USB-6009 Visual Studio 2005: Change from diff to RSE Mode
Hi, I'm really trying to learn the ends and outs of the USB-6009. Everything technically works, but now I would like to mend the example programs to do things that I actually need. For starters the Visual Basic programs initialize the USB-6009 in differential mode instead of RSE mode which is what i need. Any help on what code I need to add to change this would be greatly appreciated. I'm running AcqVoltageSamples_IntClk example program. If you need more information from me, please ask.
(3,886 Views)
I think this is in the wrong forum, I'm placing an identical one in the Measurement Studio for .NET Languages forum.
(3,882 Views)
Hi Mitch,
The particular example that you are referring to makes a call to the following method for creating the virtual channel:
myTask.AIChannels.CreateVoltageChannel(physicalChannelComboBox.Text, "", CType(-1, AITerminalConfiguration), rangeMin, rangeMax, AIVoltageUnits.Volts)
The CreateVoltageChannel method is where the terminal configuration is set for the analog input channel that you intend to use.  The example program passes CType(-1, AITerminalConfiguration) as the parameter for the terminal configuration.  What this does is casts a value of -1 to the AITerminalConfiguration enumeration.  By doing this, the default terminal configuration (differential) for the physical channel is used.  The USB-6009 only supports differential and RSE modes, so to use RSE mode you would simply pass AITerminalConfiguration.Rse as the parameter instead of CType(-1, AITerminalConfiguration)
Information about this method and all other methods used for programming DAQmx in .NET can be found in the DAQmx .NET Framework Help (Start>>Programs>>National Instruments>>NI-DAQ).
Andrew W
(3,868 Views)
Thanks! It was a bit difficult to translate the help file into what you said in your post, but it all makes sense now, thanks again!
(3,857 Views)
