Multifunction DAQ
USB 6009 Digital Input issue
      I am using USB 6009. When I am connecting the DAQ device to my computer , I am getting 5 V at all the digital input terminals. I measured this value using multimeter .I didnt connect anything at any terminals. And also checked in NI Max- Test Panel. In test panel, I've configured all the channels as digital Input lines.All the input channels are showing ON ( That means triggered on in green colour) .  I've attached the screenshot of MAX - Test panel. Awaiting for good response.
(4,189 Views)
RTFM and RTFS(pec) can answer your questions 🙂
hint: look at page 18 of the manual and you can find that there is an internal 4.7kOhm pullup 😄
Greetings from Germany
Henrik
LV since v3.1
(4,176 Views)
Many DIO on DAQ boards have built in pull-up or pull-down resistors.  So you really do need to read the specification to make sure you understand which way it will pull if nothing is connected.  The 6008 apparently has a pull-up built in.
(4,167 Views)
