Multifunction DAQ
USB-6008 read floating 24V AC
Hey,
I have a USB-6008 and want to measure the voltage at a 24V AC valve (I have no acces to the controller).
How do I have to connect this to my 6008?
I think first step will be a resistive voltage divider (10:1 for example) and  and two zener diodes to protect
the 6008.
But whats about the ground level?  Whats a professional set-up to use here?
Thanks a lot
#Andreas
(3,261 Views)
USB-6008 and professional doesn't really fit Smiley Wink
However a [3,5,7,8]B Module provide isolation and matching of input/output voltages.
Greetings from Germany
Henrik
LV since v3.1
(3,248 Views)
Hey Andreas,
The USB-6008 has an internal overvoltage protection at +-35V. because of that external protection by zener diodes are not necessary i think. but be carefull when measuring on inductive loads (your valve?, use free runing diodes)!
I would prefer an opto-coupling circuit to seperate the measurement part from the "load" part. Adapt the voltage divider to the linear voltage range of the opto-coupling device.
hope to give some ideas to you.
regards,
mario
(3,235 Views)
