Multifunction DAQ
USB-6008, linux application start-up issue
Dear all,
I am trying to put at work the USB-6008 device on Linux (Fedora10 [I know: not in the official supported systems list, but Fedora is derived from RedHat...]).
I got the last nidaqmxbase package and I went through the install process.
I started from the provided sample codes.
I have been able to write&build a basic C code to write / read digital IO's.
It seems to work pretty well except that:
- Call to the first function "DAQmxBase..." is quite long (between 3-5 seconds)
- On average, every 4 or 5 runs, the call to the first function "DAQmxBase..." in my program never returns (In this case, never can be hours, after that, I kill the process...)
The first function "DAQmxBase..." in  my case is either "DAQmxBaseResetDevice" or "DAQmxBaseCreateTask". I tried both with the same result.
Did anyone ever seen such a behavior?
Eventually what could be a possible way to investigate what append?
Ideally, what could be a possible solution?
Any idea is welcome...
Thanks a lot.
Best regards
Message 1 of 1
(3,489 Views)
