Multifunction DAQ
USB-6008 device driver needed
Hi all,
My question is how do I install ONLY the driver for an USB-6008 device for application distribution? I don't really need MAX, or DAQmx ona panel PC, instead I want to run my own application, written in CVI, that reads data through a USB-6008 device. If I create a distribution kit with LabWindows/CVI the device driveris not included in the setup, so another PC is running my application, but it can't communicate with the device...
Boti
(3,750 Views)
There is no such thing as a separate driver for each DAQ device. There is a single driver (DAQmx) for all the devices. You don't mention which version of CVI you are using but at least with 8.5, when you do a Build>Distribution, you have a Drivers & Components tab on the Edit Installer page. You can select to inlcude DAQmx and either a full install or 1 of 4 different run-times.
(3,747 Views)
Thanks Dennis for your reply!
That's bad news.
My CVI version is 7.1.0, I couldn't find such thing as Drivers & Components on the edit installer page 😞
It's a shame, that for a few kB of application I need to install hundreds of Mb of data, useless feor my needs...
Boti
(3,733 Views)
I believe that for some some of the versions of DAQmx, the different run-times are available separately from http://www.ni.com/support/. Since you are using an older version of CVI, you should probably try any upgrades on your development machine first.
(3,722 Views)
Hi Boti,
As Dennis mentioned, you can find a smaller version of the DAQmx Run-Time online at this page. This version is for NI-DAQmx 8.7.1, though it is compatible for LabWindows/CVI 7.x and later. The description on that page lists what does not get included with the Runtime 5 version. There is also a Runtime 3 version which includes slightly more support. Hope this helps,
Daniel S.
(3,706 Views)
