Hey.
Im using a NI USB-6008 multifunction I/O box. Im working on a project
were a dynamic number of transducers can be connected to this box. The
user should then be able to set the voltage range on each input, as
speciffied by the transducer, but if the user chooses to connect only 2
of max 4 transducers, the configuration sheet should only show up 2
transducer option fields, where Max, Min voltage could be chosen from a
dropdown menu.
My problem is the following:
1. How can u specify different ranges for each analog input port?
2. Is it possible in labview to have the frontpanel dynamically show
only the wanted configuration options, according to the chosen numbers
of transducers?
I have attached this preliminary attempt to accomplish the
above mentioned project, where I try to specify the ranges. Dont know
if this is the correct way to go, but any help will be very much
appreciated.
Regards
Ole
