09-20-2005 03:41 PM
09-21-2005 03:23 PM
09-21-2005 03:39 PM
Hi Lorne,
Thanks for the re-assurance. Anyways, I managed to successfully test the set-up as I wanted to, in the XP environment. Just for the record:
In MAX, when I say 'File' --> 'Export', MAX saves only the NIDAQmx configuration. To save the Traditional DAQ configuration, you have to go to 'Tools' --> 'Traditional NI-DAQ Configuration' --> 'Save Configuration As...'
Now, on the new machine, to import the configuration, I say 'File' --> 'Import', MAX imports only the NIDAQmx configuration. To import the Traditional DAQ configuration, you have to go to 'Tools' --> 'Traditional NI-DAQ Configuration' --> 'Set Active Configuration...'
One more small example to prove why NI-DAQmx rules over Traditional NI-DAQ.
-Sachin
