Multifunction DAQ
Trigger implementation with Python NIDAQmx
Hi all,
I am using Python 3.10.14 with NIDAQmx 0.9.0. I have a motorized stage, which I control via the serial port in my Python script. The stage is programed to output a trigger at the start of its movement. I want to use this trigger to start my data acquisition. I have a code that works, but I feel I'm over-complicating things and I'd like to have a second opinion.
In my code, I'm using the threading module. My idea is to start the DAQmx task (reading 6k samples in two analog input channels) in a separate thread, such that I can keep control of my stage, which ultimately sends the trigger. So, I defined a function to arm my DAQ (USB-6002 for reference):
import threading
def arm_daq(data):
    with nidaqmx.Task() as task:
        task.ai_channels.add_ai_voltage_chan("Dev1/ai0:1")
        task.timing.cfg_samp_clk_timing(rate=25e3, samps_per_chan=6000)
        task.triggers.start_trigger.cfg_dig_edge_start_trig("PFI0")
        data[:] = task.read(number_of_samples_per_channel=6000)
Then, in my main program, where I control the movement of my stage, I start the thread such that the DAQ becomes ready for triggering, and then I send the commands to move my stage:
if __name__ == "__main__":
    data = np.zeros((2, 6000))
    t1 = threading.Thread(target=arm_daq, args=(data,))
    # Instructions to move the stage
    t1.join()
Note that the data array is modified in-place within the thread and will be available in the main code automatically.
As I said, this works fine for me, but I have to commit a thread for the DAQ. And this is the reason I think I am over-complicating this. I thought the very idea of a DAQ was to offload the "processing" to a separate board (the DAQ). Can someone share their experience on this task? Is it how you'd program your DAQ as well?
Thanks for your help and take care,
David
(2,763 Views)
Committing a thread allows you to offline the processing to another CPU core.
DAQ device does not have a processor and cannot run any code. It simply reacts according to the commands sent by the DAQmx driver, which runs on a PC.
If you are not doing any parallel processing, using threading does not make any difference.
https://tmesystems.net/
(2,735 Views)
Makes sense. I couldn't find any implementation of this before posting. Is it how you would implement this solution as well?
Thanks a lot.
David
(2,691 Views)
I never had to use threading with DAQmx.
nidaqmx-python/examples are all you need to get started.
(2,680 Views)
