Multifunction DAQ
Timing glitch when logging analog input on USB 6002
I am trying to log an analog input at 2 kS/s while outputting waveforms to 2 analog outputs. I've tried many methods but right now I'm running the logging and the waveform generation on different threads as I was unable to get accurate logging on the same thread. However, I am still getting timing glitches when I feed a 20 Hz sine wave from the wave generator on my oscilloscope. I am creating the program using python. Has anyone experienced this before or have any insight?
(1,068 Views)
Please attach actual code, nobody can run or edit the code with pictures.
Santhosh
Soliton Technologies
(1,042 Views)
My bad, heres the code.
(1,000 Views)
