Multifunction DAQ
Time Problems
We want a program to take voltage and time data for a specified time at a given sampling rate (typically tens to hundreds of seconds at 10Hz). I'm using a DAQmx vi to interface to the PMT with a NI USB 6009, 8input/14bit. I've run into two problems having to do with time:
1. When I save the data after the loop executes (the write to measurement vi that's outside the while loop), timing data is lost. Note that in the "outside" text file (from the screenshot), there are iteration numbers or something in the time column (0,1,2...etc.). Why? And, how can I retain the time data? I'm thinking of using an array, but I'm not sure. Basically, I want the data saved "inside" the loop (see "inside" text file screenshot) to be the same as that saved outside (because I want the "save" prompt to occur at the end of the program execution).
2. I have a millisecond timer in the loop and it's seems to be working fine (if you look at the time data from the inside loop save). But, notice the lapse between time = 0 and the next data point. Is it a delay in my program? I'm thinking probably, but how can I (or can I) get rid of it?
Also, if you have some critique of my program, please share them.
(3,107 Views)
Please keep in in 1 post.  Link to the same post in the LabVIEW board: http://forums.ni.com/t5/LabVIEW/Time-Problems/m-p/2172296
(3,099 Views)
