Multifunction DAQ
Test panel
I have a queston on "Acquisition Mode" in Test Panels. What are the differences of Continous, Finite and On demand?
2) How do you set "Rate" and "#Point to read" to measure a signal? What is minimum value? Which one is for measure sth accurately? Is "#Points of read" talking about per second to count?
3) I heard I can read current on an analog line, I mean going into the Measurement and Automation Explorer (MAX) and creating an analog input current task. This task will require you to provide the shunt resistor value, so you will need to add a resistor. Can we do that in test panel? How about the shunt
resistor value? Where should we add? Do you know about it?
Many thanks if you can reply to me promply. I am in a urgent.
I wish you can answer my questions directly.
(3,137 Views)
The on demand acquisition mode configures a task to read samples one at a time using software timing, finite acquires a predetermined number of samples using hardware timing, and continous acquires an unlimited number of samples also using hardware timing.
The rate control only applies to finite and continous tasks, and it indicates how many samples per second are to be acquired.  The "# of points to read' is how many total samples in a finite acquisition, or how many samples per read (per update of the test panel graph).
Unless your hardware is capable of measuring current directly using an internal shunt resistor, you will need to wire an external shunt resistor before making current measurements.  The current input task then uses the value you provide as the external shunt resistance to convert the voltage read from the device into a current.  The value of the shunt resistance should be chosen such that the amount of power consumed is reasonably low, yet still produces a large enough voltage to be sensed by the DAQ device.
The device test panels are intended to verify device configuration and external connections, so they do not provide for the application of an external shunt resistor.  However, you may use open a test panel from the analog current input task and the correct scaled measurement can be viewed from there.
I hope this answers most of your questions.  If not, please reply back.
Jason
(3,101 Views)
