Multifunction DAQ
Temperature measurement with MIO 16E-4 and SCB-68
Hello NG,
we need to log the room temperature (range 5°C to 40°C) with one of our measurement stations. The station uses an PCI MIO 16E-4 and a SCB-68 connector block. LabVIEW is used as programming language.
What is the easiest way to log the temperature with this configuration. Using a thermocouple with the MIO 16E-4 will result in bad values, because the noise will be higher than the signal.
Any idea for an easy solution?
Thanks a lot.
Michael
(3,096 Views)
Michael,
the easiest way to measure temperatures within the range you have specified is to use a IC-sensor like the IC LM35 DZ. You could power this sensor with the +5V provided by the PCI-MIO-16E-4.
I hope this helps,
Jochen Klier
National Instruments Germany
(3,069 Views)
