Multifunction DAQ
TDMS reading time delay
I'm starting with Labview, and I have some trouble to make it work properly. I use the student version 8.20.
I have a problem to set the reading time of a TDMS file , whose data must be sent by the analog output of a USB6009.
The project aims to record the signal of an electrocardiogram, and reproduce it later. I get the signal from the analog input of the USB6009, (10 samples at 500Hz) and write it in a TDMS data file (REC option ). Execution time loop last of 20ms (50Hz) . Then later, when the user wishes, he can read the TDMS data file (PLAY option) , and recovers the signal from the analog output USB6009.
As the DAQ assistant output can send only one sample at a time, the loop "PLAY" should go 10 times faster, to keep pace temporal signal (2ms-500Hz), but I can not set this parameter.
As a result, reading the data takes too long. So for 2 minutes of recording, it takes nearly 3 minutes reading the same data.
Does someone knows how to set the time to execute a while loop ? or, is it possible to record in the TDMS file the temporal data?
Thank you very much for your help.
Sincerely,
Sebastian Avila.
(2,905 Views)
Your TDMS file will read much faster if you use the NI_MinimumBufferSize option, or if you defragment the file after writing. See http://digital.ni.com/public.nsf/allkb/63DA22F92660C7308625744700781A8D.
Herbert
(2,902 Views)
