Multifunction DAQ
TDMS high sampling data acquisition issue
Dear LabVIEW Friends,
I am facing some strange issue with Direct TDMS logging on DAQmx 9.4 and looking forward for your help to resolve this.
Initially on the PXI DAQmx 9.3 has installed and I was successfully able to log the data with high sampling rate 2M, as well as I was successfully using the different functions TDMS file splitting.
Everything was working well but now problem is by mistake PXI has formated and installed new DAQmx 9.4 and other softwares.
Now software is only able to log the low resolution data 10 K but file splitting is working properly, but when we try to log the high sample data its giving some error. I have tried with different options but not able to get any solution.
Please help me to find if I have missed any setting or its happening because of DAQmx 9.4.
Thank You.
-Santosh
(2,929 Views)
What error are you getting?
Did any of your hardware configuration change at all? How many channels at 2 MS? What device?
Andy McRorie
NI R&D
(2,914 Views)
Sorry for delay in response. Please find the attached error. I dont think any configuration has changed.
I am trying to acquire 16 channels.
I am using following hardware
PXI Controller - 8133
Chassis – 1082
Mod Device – 6368
OS – Windows
LV Version – 2010 Service Pack 1
DAQmx Version – 9.4
(2,893 Views)
