Multifunction DAQ
Syncronization of 2 pci-6014
Hi.
I´m using 2 pci-6014 cards and Labview 7,1 and I need to get these syncronized.
Is it possible and how should I do it in that case?
According to the information I have it´s not possible to use a rtsi-cabel on these cards.
(3,132 Views)
You are correct that you don't have RTSI support for those devices.  So a suggestion:  You could use an external clock to send the same clock signal to both devices.  Additionally, you could produce this pulse train with one of the on board counters from one of the 6014s, so you wouldn't need another device.  This method will, of course, require some external wiring of the clock signal, but thats probably your best option.
-Alan A.
(3,121 Views)
Hi. I am using pci 6014 to control stepper motor. I am not able to generate clock pulse in order to move the motor. I am using the DIO port to set cw/ccw and enable. Also wanted to kow how to generate a single pulse high low high.
(2,836 Views)
