Multifunction DAQ
Synchronize multiple DAQ
How to synchronize multiple DAQ to read analog inputs voltage, for example:
A. PCI 6250 with PCI 6251.
B. PXIe1085 with PCI 6250.
C.USB DAQ and PXIE and PCI.
(2,471 Views)
Each device will have its own timebase and they won't match exactly.  You will need to supply a shared timing signal to all of them via physical wiring.  All the devices will need to either derive their sample clock from this signal (or possibly use directly as a sample clock).
I often sync devices controlled by the same PC without using a trigger, but your situation is different.  It might call for a start trigger.  I expect you probably have at least 2 separate PC's involved to support PCI, PXIe, and USB at the same time.  The task sequencing I typically use may not be practical across 2 or more PC's, so it might be simpler to use triggering.  (Note: you shouldn't have to share the trigger signal.  Just make sure that the *source* of the shared sample timing signal doesn't start generating it until the trigger asserts.)
-Kevin P
(2,445 Views)
