Multifunction DAQ
Synchronising using MAX
Hi All,
I am trying to synchronise two PCI cards (PCI-6133) and (PCI 6534) using MAX. I have connected both cards using a RTSI cable.
The 6534 has been selected as the master (internal clock) and the 6133 has been selected as the slave (external clock). I have used RTI07 as the clock line.
I have also tried to trigger both cards to start at the same time without any success using MAX. I have chosen a digital edge trigger selecting both cards to use PIO1. Again nothing happens and i get an error returned.
Is it possible to synchronise / trigger two separate cards using MAX? I dont understand why this feature would be available if it cant be done.
Andy
Message 1 of 1
(3,147 Views)
