Multifunction DAQ
SynchAI-AO example does not work
Hi!
I am using a USB 6621 and I tried to execute the ANSIC C SynchAI-AO example code shipped with the hardware.
First I got the following error message:
DAQmx Error: Source terminal to be routed could not be found on the device
Make sure the terminal name is valid for the specified device. Refer to
Measurement & Automation Explorer for valid terminal names.
Property: DAQmx_DigEdge_StartTrig_Src
Property: DAQmx_DigEdge_StartTrig_Edge
Source Device: Dev1
Source Terminal: ai/aiStartTrigger
Task Name: _unnamedTask<1>
Status Code: -89120
Then I changed the following line (the rest of the code remains unmodified):
DAQmxErrChk (GetTerminalNameWithDevPrefix(AItaskHandle,"ai/aiStartTrigger",trigName));
to:
DAQmxErrChk (GetTerminalNameWithDevPrefix(AItaskHandle,"ai/StartTrigger",trigName));
Now I get a different error mesage:
DAQmx Error: Measurements: Non-buffered hardware-timed operations are not supported for this device an Channel Type.
Set the Buffer Size to greater than 0, do not configure Sample Clock timing, or
set Sample Timing to On Demand.
Status Code: -201025
I am little bit confused.
Is the execution of this example not possible with my hardware (if so, were can I get information about which example codes work with my hardware and which do not)?
Or is there a bug in the exampe code?
Thank you in advance for your replies!
Kind regards,
Christian
(3,910 Views)
Accepted by topic author Legufix
Hi Christian,
Thanks for posting about the problems you found with this example program. Changing "ai/aiStartTrigger" to "ai/StartTrigger" is correct. The problem that is causing error -201025 is a missing line of code (which goes right below the call to GenSineWave()):
DAQmxErrChk (DAQmxWriteAnalogF64(AOtaskHandle, 1000, FALSE, 10.0, DAQmx_Val_GroupByChannel, AOdata, NULL, NULL));
Once you add that line, it should work (tested with a USB-6229; I assume you have a USB-6221?). These problems have been reported to R&D as CAR #181942.
Brad
Brad Keryan
NI R&D
(3,894 Views)
Hi Brad,
Now it works - thank you!
Kind regards,
Christian
(3,886 Views)
