Multifunction DAQ
Status of a cleared task
Hello:
I use DAQmxClearTask to clear some specific task.
Is there a way to know that a task was cleared already using functions from NI-DAQmx library?
Thank you,
-Ilya.
(3,422 Views)
Accepted by topic author ilyak
I think that any operation on a cleared task would result in an error. So just do anything like reading from a property node and check the error code.
Felix
(3,409 Views)
Hi ilyak-
     Felix is correct.  If you try to use a DAQmx function like a DAQmx Read on a cleared task, you will get an error indicating that the task is invalid.
     Have a great day!
Gary P.
(3,398 Views)
