Multifunction DAQ
Status code : -200278 = how to read samples when referenceTrigger and AsyncReading
Hello, I've got a 6251 PCI card. I want to trig to APFI0 and read 3 channels-> everything is ok if i make a sync read. Now I want to install an event handler and make an async reading. When I make a second "ReadMultiSampleAsync (-1, m_data, NULL)" an exception occurs : Status code : -200278 I don't know what happens. The message says : "the final sample acquired can be determined by querying the total samples acquired after an aquisition has stopped". I cannot find this API... Could you help me ? I attached a mini Visual C++ Project wich shows my problem.
(2,998 Views)
There is a KB about this issue at this link.
http://digital.ni.com/public.nsf/websearch/4159A4241B8A24B3862570EC007AB6B7?OpenDocument
Johan G.
NIF
(2,978 Views)
