Multifunction DAQ
Static DIO - PXI 6341
I am new to PXI's and I am studying the same. Can someone explain me static digital output (PXI 6341) and it's voltage specification.
(2,759 Views)
Basically, the output voltage is based on the amount of current the signal's sink requires.  With a high impedance or no load, the output will be 5V.  If the load requires 50mA, the output of the digital output will be closer to 3.3V.
(2,744 Views)
