07-02-2007 07:32 AM
07-02-2007 09:01 AM
07-02-2007 09:09 AM
I was leaning towards the GS1005002 on this page:
http://www.cherrycorp.com/english/sensors/gs1005_1009.htm
I'm not really tied to that, I just have a lock nut with four notches in it that would make a handy 'gear' and pretty much any geartooth sensor would work fine. These sensors work with 5-24v. I'm not sure if the output amperage is tied to the power supply amperage, or if it's regulated by the sensor--either way, if there's a better geartooth sensor for interface with NI, I'm all ears. I have to have it ordered today and implemented no later than Thursday though.
FWIW, actual RPM is not a major concern of mine right now--it will be in future tests--this sensor will simply be used to detect if a shaft has stopped spinning due to failure of a coupler rather than motor shutdown.
Timely responses are appreciated IMMENSELY! Thanks!
07-02-2007 10:00 AM
Took a look at datasheet and crunched a couple of quick numbers. Max load on your 5V supply will be 16.64mA.
Sensor is specd to have a max current draw of 6mA. Recommended external pullup is 470 ohms when using 5V supply. Worst case current draw will occur when output transistor inside sensor is on and full 5V is being dropped across the 470 resistor. That means that 10.64mA of current will be flowing through the 470ohm resistor and the sensor will be drawing 6mA to power itself for a total of 16.64 You just need to verify that the supply you use can source that much current at 5V. Depending on how you are using the rest of your digital I/O, 6211 may be able to supply the 5V. See the spec sheet for more details. . http://www.ni.com/pdf/manuals/371932c.pdf
If you use a supply other than the 6211, make sure it is properly referenced to the 6211.
0-5V signal to your counter is exactly what you want.
There are some high output speed pickups that generate large ac signals that can damage hardware.
Good luck and let me know how you make out.
07-02-2007 10:13 AM
07-02-2007 10:20 AM
07-02-2007 10:33 AM
07-02-2007 10:47 AM
Spec says 5V supply on 6221 is good for 1 amp. More than enough for your application.
Power connections:
Connect 6221 +5V signal to sensor VCC signal.
Connect 6221 D GND signal to sensor ground signal.
( Note: Strongly advise using twisted/shielded cable for connections to sensor. )
The signal will then be connected to which ever digital input is configured as the counter input. You determine this either in MAX or in your VI.
This sensor should work just fine. Just don't forget to hookup external pullup resistor.
07-02-2007 10:54 AM
Ok, that's what I was thinking... Just wanted to make sure there was no grounding or weirdness involved.
I made a couple magnetic sensors before with the pull-up and tested them with a VOM so I'm good there. Just needed some verification and details, and you helped immensely!
I'm off to order my sensors, and THANKS!
