Hello. I am trying to perform a delayed analog input measurement using a cDAQ 9178 and NI-9201 analog input module. I am tryiung to port code running on an NI-4363 but am running into an error:
det_task.ai_channels.add_ai_voltage_chan(self.detector_channel)
det_task.timing.cfg_samp_clk_timing(rate=ACQ_RATE, source = 'PFI1',
samps_per_chan=samples,
active_edge=Edge.FALLING)
det_task.timing.delay_from_samp_clk_delay = peak_delay
When I run this, I get the following error on the last line:
inidaqmx.errors.DaqError: DAQmx Timing property specified requires per device configuration. Explicitly specify the device(s) to which this property should apply. Property: DAQmx_DelayFromSampClk_Delay
