Multifunction DAQ
Some or all of the samples requested have not yet been acquired: API change responsible?
My Delphi program, which works fine under NI-DAQmx 8.9.0f4 on one set of hardware, is failing under 9.0.0f2 on what I have been assured is equivalent hardware. The error is "Some or all of the samples requested have not yet been acquired...". This happens even at slow digitization rates, and I am coming to suspect that the API has changed subtly in the transition from version 8 to 9. How likely is this? Now that I have access to the source code on the new hardware (NI PXI-1044 with embedded PXI-8110 computer) is there something I can do to check this?
Message 1 of 9
(9,655 Views)
Hi francisb-
Which DAQ hardware are you using?  Are you using an external signal for the sample clock or a start trigger?  There was no intended API change that would suddenly introduce timeout errors into your operation, but more insight into your hardware and software setup would help us make suggestions on what might be going wrong.
Message Edited by Tom W [DE] on 02-01-2010 10:51 AM
Tom W
Message 2 of 9
(9,645 Views)
Hi Tom,
Sorry for the delay in replying. Here are some details about the two setups.
Old (works):
NI-DAQmx 8.9.0f4
System chassis: PXI-1042 8 slot
Interface: PXI 8336MXI-4 (Optical link between PC & NI Chassis)
Digital / Analogue IO: 4x PXI-6225M
New (doesn't work);
NI-DAQmx 9.0.0f2
System chassis: PXI-1044 (embedded controller)
Digital / Analogue IO: 4x PXI-6225 (in slots 2-5)
Board acquisition is synchronised by setting Ref Clk Src to PXI_Clk10 (rate = 10MHz). I can post code if necessary, but essentially it is modelled on the C example ContinuousAI.c
Francis
Message 3 of 9
(9,590 Views)
Hi Francis-
I'm not familiar with ContinuousAI.c.  Can you point me to that code?
In the meantime, let's talk about the DAQ parameters you're using in your code.  How many channels on each device are you addressing?  What sample rate are you using?  And since you mention continuous AI, I assume you're looping on a DAQmxRead call to retrieve data.  How many samples per loop are you attempting to read?  What timeout are you specifying for DAQmxRead?
The error you're seeing is generically a timeout error.  It could mean that you literally aren't waiting long enough for the requested samples to be acquired or that, for some reason, either your trigger or sample clock is not being recognized at the rate you expect it to.  A quick glance at your code might help us make more recommendations.
Tom W
Message 4 of 9
(9,560 Views)
Hi Tom,
The original C example file is:
National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Synchronization\Multi-Device\Continuous AI\ContinuousAI.c
Here is my own Delphi code which follows the same series of calls (edited to show just the relevant lines):
StopADCs; DisableFPUExceptions; for device := 1 to NumDevices do begin // NumDevices = 4 or 8 CheckError( DAQmxCreateTask( '', ADCTask[device]) ); // NCHANNELSPERBOARD = 65 (64 for camera plus 1 extra analog input) channels := DeviceName[device] + '/AI0:' + IntToStr(NCHANNELSPERBOARD-1); CheckError( DAQmxCreateAIVoltageChan( ADCTask[device], PChar(channels), nil, refmode, // DAQmx_Val_RSE or DAQmx_Val_NRSE vmin, vmax, DAQmx_Val_Volts, nil) ); CheckError( DAQmxCfgSampClkTiming( ADCTask[device], PChar(''), srate, // 100, 200, 500 or 1000 Hz DAQmx_Val_Rising, DAQmx_Val_ContSamps, Floor(srate)) ); end; // register master task callback CheckError( DAQmxRegisterEveryNSamplesEvent( ADCTask[1], DAQmx_Val_Acquired_Into_Buffer, NFRAMESPERCALLBACK, // 10 0, @EveryNCallback, nil) ); // synchronise board acquisition for device := 1 to NumDevices do begin CheckError( DAQmxSetRefClkSrc( ADCTask[device], PChar('PXI_Clk10') )); CheckError( DAQmxSetRefClkRate( ADCTask[device], 10000000.0 )); end; // 'committing' supposed to reduce delay between starting tasks for device := 1 to NumDevices do begin if CheckError( DAQmxTaskControl( ADCTask[device], DAQmx_Val_Task_Commit )) then begin EnableFPUExceptions; Exit; end; end; for device := 1 to NumDevices do begin if CheckError( DAQmxStartTask( ADCTask[device])) then Exit; ADCActive[device] := true; end; EnableFPUExceptions;
 Then the callback routine is:
function EveryNCallback(thandle: LongInt; evType: LongInt; nSamples: LongWord; callbackData: Pointer): LongInt; cdecl; // camera 1 (4 boards x 64 channels) for device := 1 to 4 do begin rc := DAQmxReadBinaryI16( ADCTask[device], 10, 0, DAQmx_Val_GroupByScanNumber, @ADCBuffers[device, 1], 1000, nread, nil ); // <---- Error here at all sampling rates if rc <> 0 then begin DAQmxGetErrorString(rc, RunErrorDesc, LONGSTR-1); RunError := true; DAQmxStopTask(ADCTask[device]); end; NSampsRead := nread; end; // if no error... // Process data in ADCBuffers // Repeat above for camera 2 if attached (NumDevices=8)
 Hope this provides all the info you need. I can post more code if necessary.
Francis
Message 5 of 9
(9,552 Views)
Accepted by topic author francisb
Hi Francis,
Does your program still call DAQmxCfgDigEdgeStartTrig() for all of the slave tasks? If you don't do that, the devices won't start acquiring data at the same time, and since you're passing 0 for the timeout parameter to DAQmxReadBinaryI16(), out-of-sync devices could definitely cause timeout errors.
Also, you must make sure to start the slave devices before the master device, so that they are already waiting for a trigger when the master device starts.
Brad
Brad Keryan
NI R&D
Message 6 of 9
(9,549 Views)
In addition to what Brad mentioned, consider increasing your sample interval.  A sample interval of 10 (assuming the comment is accurate) is rather small for an acquisition rate of 1kHz.  This would mean that you need to be calling DAQmxRead to read 10 samples 100 times each second (times four devices).  I wouldn't be surprised if your system cannot keep up while the callbacks and the small read sizes (therefore, read overhead impact is maximized) are taxing your system.
You might try something like 1000 samples for the interval at 1 kHz.
Andy McRorie
NI R&D
Message 7 of 9
(9,541 Views)
Hi Tom,
That appears to have done the trick! I haven't soak-tested data acquisition yet, but it certainly runs for minutes without any errors.
Many thanks for your suggestion.
Francis
Message 8 of 9
(9,485 Views)
Apologies - my previous reply should have been to Brad. Thanks, Brad!
Andy,
The reason I used that sample interval was so that I could do some continuous display updating while acquisition is running and have it appear reasonably snappy at all rates. That means 100/s at 1kHz and 10/s at 100Hz, the normal range of data digitisation rates. Having one callback per sample does indeed put a strain on the CPU. However, with one callback every 10 samples, CPU usage is less that 10% (in fact, ~3% on the new hardware). I could vary the number of samples per callback for different digitisation rates, but that seemed like an unnecessary complication given that 10 works well over the working range.
Message 9 of 9
(9,483 Views)
