Multifunction DAQ
Software Licencing using NI-DAQ Serial Number
I would like to licence an application based on licencing the software to work with specific pieces of NI hardware.  I.e. I want my customers to be able to install the software on as many PC's as the like, but it will only work with as many NI DAQ cards as they purchase licences for.  For each NI-DAQ card they purchase and licence with my software I will provide a licence file with the serial numbers embedded, so any copy of the software will work with any of the licenced hardware devices.
Is this a good idea or is there any easy way to change the serial numbers of DAQ hardware?  Target hardware are E and M series DAQ cards, both PCI and USB.
Thanks, Ben.
(3,826 Views)
Hi Ben,
No its incredibly difficult to change the serial numbers of cards (I have never actually heard of this bei ng done outside of NI) so I would say that this is a good method to take with regards to your software licensing.
You just need a DAQmx Device Property Node to extract the Serial Number.
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,787 Views)
