Multifunction DAQ
Simultanously use NI 6534 sending data and return values from a GUI using threadpool.
Running NI 6534 in a while loop that repeats its function every 31milli seconds using a threadpool function. Threading work while running GUI and NI 6534 but, when I hit the DONE button on my GUI, I would like the test to continue to its next operation while the NI 6534 is still running its while loop. I am communicating with a board under test that requires a pulse every 31milliseconds. While the NI 6534 is outputting this signal I need to do some voltage measurement or rest of my test.
(2,761 Views)
I am not completely sure if I follow what you are trying to do.  If you are having problems with the multi-threading of your application, I would recommend going to the Example Finder at Help >> Find Examples and looking at the multi-threading examples.  Also, you may want to post in the CVI forum to get the best advice about multi-threading.
If you would like help using the 6534, there are also examples in the Example Finder under Hardware Input and Output >> DAQmx.
If you would like to post back additional information about your application, we would be happy to help.
Laura
(2,739 Views)
