Multifunction DAQ
Signal problem using NI-USB-6361
Hi, I'm Kwangmin.
Currently, I try to test the HTS coil using DAQ system.
The DAQ system is composed of SCXI-1000, SCXI-1125(with 1328) --> SCXI-1349-->NI-USB-6361--> LabVIEW.
But, the measured signal has the big problem.
I connected NI-USB-6361 to the module-1 of SCXI.
Module-1's signal is good but module-2, module-3, mudule-4 signals are very unstable.
If, I connected NI-USB-6361 to the module-2 of SCXI.
Module-2's signal is good but module-1, module-3, mudule-4 signals are very unstable.
I didn't find the reason of this problem.
My English is very poor and not enough for explaining to this situation.
So, I attached the test results.
Please give to me your good comment.
-Kwangmin Kim
(2,789 Views)
What is the rate you are using for acquiring the data? Have you verified if acquiring at a slower rate also results in this problem?
Have you also tried the different Digitization Modes, Multiplexed and Parallel? Go to details->Cabling.
If you would feel more conformtable talking about this in your native language, I would also suggests posting this on that section of the forums.
(2,734 Views)
