Multifunction DAQ
Signal gating and integration
I have an application which I wish to calculate the integration of an incoming signal which is above a certain
threshold.
I have not attcahed the application vi but have attached TutorialGenAnalyzeDisp JS.vi and modfied it to try and
do this but I am having problem in getting it to work correctly.
What I want it to do is to clip the peaks off the sine wave above 0.5V using the relay function and feed this
into a integration routine and display the result. The result should be the area under the sine wave above
0.5 and I should be able to get the full area or a fraction of depending on my dt value I feed into the integration
vi.
Instead the relay output does not seem to give me the clipped tops of the sine wave rather the sine wave
coming & going.
Any tips on how to proceed greatly appreciated.
Javed
(3,217 Views)
Hi Javed,
The Relay express vi won't return what you want from the signal. Instead you could use the Mask and limits express VI. I have modified your vi to use this instead of the Relay. Is this waht you wanted?
Reagrds
Jon B
NIUK
(3,195 Views)
