Multifunction DAQ
Signal Express file I/0 Problem
I have been logging data in Labview SignalExpress version 1.1 all week.  The data has been snapshots.  The file had around 15 snapshots and SignalExpress crashed.  When I opened up the project file the snapshots were gone.  Is there anyway to prevent this?  I had been saving the project on a regular basis.  Apparently the last save corrupted the file or the crashed SignalExpress did.  Is there anyway to retrieve the data?
(3,020 Views)
Hello msantora,
Thanks for your post!
I see that you are having some trouble with Signal Express. I am sorry to hear that your snapshots are not showing up in your project  log area. One thing to try is to open a blank project and try to import Snapshots from another Project to see if you can recover them that way. Simply right click on Snapshots and select Snapshots from another Project. The Snapshots are saved within the project file and should be saved automatically when they are taken. If you could possibly post your project here on the forums I could try and recover the snapshots on my end as I have a newer version of signal express. If both these efforts fail I apologize but the files may not be recoverable. Give that a try and let us know how it turns out.
Have a great day msantora
Cheers!
Corby_B
http://www.ni.com/support
(2,992 Views)
