Multifunction DAQ
Serial input on the digital input side of a DAQ board.
I am setting up a test station that will require communication with three (and maybe four) serial devices.  I have a USB 6009 DAQ board and right now I will only have one analog signal going into it.  Is it possible to take data coming from the serial port on a sensor and have it be read on the digital input ports of the DAQ board?  If there is a way, I assume that the same serial data could be sent to each digital input line and a clock could be used to tell each digital channel when to read a bit.
Thanks.
Corey
(2,751 Views)
That was just asked and answered here. You don't even have a clock input to the digital with your 6009.
(2,746 Views)
