Multifunction DAQ
Sending/Receiving Signals using DAQ
I'm new to Labview and having some difficulties. I'm looking for some simple examples or tutorials that will take me through the process of sending and receiving both analog and digital I/O's. I've read through the user manual and searched on-line but haven't been able to locate anything very simple. I'm looking along the lines of creating a simple light switch. Any help or advice will be greatly appreciated.
(2,676 Views)
Couple of questions for you -
  1. What multifunction daq board are you using?
  2. What version of LabVIEW?
  3. What operating system?
Basically, the best examples that you're going to find will be in the LabVIEW Example Finder. You can find this by opening LabVIEW and then clicking on Help >> Find Examples... The shipping examples with LabVIEW are very extensive and in depth, but they are more vertical meaning that you probably wouldn't find any that did both AI and DIO at the same time.
To find examples such as AI and DIO at the same time, or at least AI and DO at the same time, you will want to search through the example code library. If you give me some more informa
tion, I might be able to help you find something if you are not able to.
Jared A
(2,676 Views)
