Multifunction DAQ
Self-test error 50010 on PCI-6229
I am attempting to install a PCI-6229 Card with accesory SCB-68 on Windows XP and although MAX will recognize the device when I attempt to run a self-test I receive the error message Error 50010.  I have  virtually no knowledge of the board and I naturally have no idea what this means.  The computer is new as is the board so I doubt that the problem lies with either of them structurally.  I just want to know what the error message means and how to fix it.  Thanks.
(4,261 Views)
First shot,
Try inserting your DAQ card in a different PCI slot and see if you still get this error
Which version of NI DAQ deveice drivers are you using??
See if upgrading to latest version of DAQmx 8.5 solves this problem
Dev
(4,248 Views)
Thanks Dev,
After noticing some similar queries I did download DAQmx 8.5, however that didnt seem to help.  I will try inserting the card into another slot and I will let you know.
Aaron
(4,243 Views)
It all looks good, thanks a lot
Aaron
(4,236 Views)
