11-13-2007 03:01 PM
Hi:
Thanks for the reply. Now I start using the PCI-6251 card for input&output function, and one of biggest problem is that I need to have a very low noise resolution. Therefore,
I would like to: Is there any reference telling people how to eliminate noise from environment/wires/etc. (Besides adding a filter) when measuring using DAQ card? Do NI sell shielded BNC cable?
Also, could you please tell me what's the diameter of the screw in CB-68LP card? Thank you very much.
Jason
11-14-2007
06:40 PM
- last edited on
01-29-2025
08:05 AM
by
Content Cleaner
02-05-2008 09:51 AM
Hi:
I have a question about reversing the sign of input voltage correspond to a variant output voltage value. So my experimental setup is:
I applied a constant positive input voltage, say 2V, to a device consists of electrolytes, and measure the output current. Besides, I have converted this output current to an equivalent voltage value, so in other words, I am measuring an output voltage value correspond to a constant input voltage.
Also, my device's equivalent resistance would change with time, and I plan to "inverse" the constant voltage input , say 2V to negative input -2V, when measured output voltage drop/increase to some value.
Could you please tell me how to implement this process using Labview's GUI? Or releveant references so that I will have an idea where to look up for this specific application? Thank you very much.
Jason
02-06-2008 11:46 AM
02-21-2008 11:41 AM
Hi:
My application is that I need to First generate an analog output(voltage), and then based on the value of the signal I measured, I would update/change the output voltage. However, the example above doesn't start generating the output voltage until after DAQ measured the signal. So with my application, could you please give me some examples? Thank you very much.
Jason
02-22-2008 12:31 AM
Hi:
The attached file is the one I wrote for my applicaiton. So what my code did is that i generate a voltage using DAQ assistant, at the same time measuring the corresponding value from using another DAQ assistant. When the value goes has some kind of pulse,i.e., goes over value of 4 and goes back below the value of 4, I Reverse the bias of the output voltage value.
My biggest question is that: Why is the indicator at left, named" voltage indicator", attached to the static variable "input voltage control", cannot be changed correspoinding to the static variable??
Since this is the way I tried in order to change the output according to input, could you please tell me how to change it, so that the input control to the DAQ assistant(generating the voltage) can be changed accordingly? Thank you very much.
Jason
02-22-2008 12:10 PM
