Multifunction DAQ
Scan_start
dear sir;
I m gettting data through scan_start and scan_setup api in double  buffer from 8 channels and i set daq rate to get the two minute data.
now after the one minute i want to seperate the data of each channel into 8 buffers please tell is there any api that can give me the 8 channels data in 8 different buffer..?
                                                             THANKS
        ajmal
Lead Data Scientist
(3,430 Views)
Hello ajmal,
Your best bet would be to simply break up the array that contains all 8 channels into 8 different arrays.  There is no NI-DAQ function call that returns 8 arrays of data.  You will always get one array, so you will need to do the array manipulation in whatever language you are programming in (C, VB, etc.).
-Alan A.
(3,419 Views)
