Dear, Measurement Background:
I had done measurement NI DAQ unit (Model: PXI1033, with NI-6143 measuring unit). Measurement type is Voltage.
I am saving the measurement file in to *.tdms file. I want to read and remove some waveform data from *.tdms file and I have to write back in to another file in *.tdms file. In the enclosed TDMS.vi, I was obtained data from measurement file and writing back to result file. Both are containing same data but, the file memory size are different.
My application requirement is, I want reduce the measurement file size by removing some unwanted data.
Kindly copy the Measurement.tdms file in to same VI location. Regards. Vinothkumar P
