Multifunction DAQ
Sampling Rate for Load Cell
Hello All,
I am using DAQ PCI 6221 (68 pin), I have to measure 2 load cell values continuosly, I am measuring the signals within a while loop, the load cell amplifier gives me 0-10 V Dc output for 0-20 kg. load.
I have done proper shielding of the cables. and chosen the sampling rate as 1Khz and samples 100, but I am getting a varying signal when I have put certain load say 5 kgs the reading should be stable at 5.000 kgs but it is quite unstable, keeps floating between 5.000 to 5.050.
I think I have some problem in setting the sampling rate, I also tried sampling rate as 100Khz and no. of samples 100000, in this case I get a stable value but aquisition becomes slow (obvious), so what should be criteria to choose sampling rates and no of samples as I have to measure other parameters such as temperature and pressures.
With PLC analog module I get very stable result for the same load cell and amplifier.
Kindly provoide some suggestions.
Thanks & Regards
James
Using LV 8.0
(5,101 Views)
Which mode have you configured the channels/connected the signals in Single ended or differential??
I would recommend you connect in differential mode and see if you get more stable readings
Read this link and its related links for more information on the same
(5,083 Views)
Dear Devchander
I tried using both RSE and Differential, but not much difference.
(5,073 Views)
