Multifunction DAQ
SVT Filters Settle?
Using Fractional octave analysis vi and Infinite # of samples, why do the filters settle when my frequency range is set for 25Hz to 10kHz but not 10Hz to 10kHz? I'm inputting real signal not "Simulate Signal vi".
(2,820 Views)
What do you mean when you say that you are using an infinite number of samples? Are you performing a continuous acquisition? What device are you using? Do you see the same behavior with a simulated signal?
-Jack
(2,797 Views)
