Multifunction DAQ
SHC68-68-EPM screwlock
I am using SHC68-68-EPM cable with this mating connector: https://www.digikey.no/en/products/detail/te-connectivity-amp-connectors/2-5174225-5/1121345  (PN: 2-5174225-5), as recommended by NI.
The connector on cable has UNC 2-56 thread while the connector 5174225-5 has M2.5
Previously I was able to use screwlocks https://www.digikey.no/en/products/detail/harting/60010009013/3181866?s=N4IgTCBcDaIBwBYDMBaAbAVgOwAY...  (PN: 60010009013), but they are no longer produced.
Searching this forum, it seems like the jackscrews from NI, PN: 187949-10, are the ones that are compatible. The questions I have are:
Am I right about this?
Where can I find the drawing for 187949-10?
Are there any other options when it comes to jackscrews?
(1,438 Views)
Just use a regular screw?
-AK2DM
(1,401 Views)
Good idea, but strruggling to find an M2.5 30mm screw from normally used suppliers.
(1,354 Views)
