Multifunction DAQ
SH68-68 Wirelist (pinout)
Can I get the wirelist or pin to pin connections for SH68-68-D1 Cable. I am trying to connect my PCB to the PXI6704 using this cable.
(4,167 Views)
Does this info help out?
http://forums.ni.com/ni/board/message?board.id=250&message.id=24376#M24376
(4,159 Views)
Thanks, but I still can't make sense out of the wiring scheme. It seems to me if I follow the general approach for those other listed cables, then this sh68-68-D1 cable would have about half of the analog outputs twisted with ground, and about half of the analog outputs twisted together. This doesn't seem right to me.
(4,153 Views)
The SH68-68 D1 cable was intended to be used with our DIO/TIO boards.  I took a quick look at the pinout for the 6704 and compared it to the D1 cable's wirelist and it looks like each of the AO channels is paired with a ground.
I have attached its wirelist for the SH68-68 D1 cable.
Sal
(4,138 Views)
Thanks Sal, this answers all my questions.
(4,132 Views)
